I have the HTC Incredible.
My phone no longer notifies me of my emails in gmail. I tried unsyncing then resyncing everything associated with it with no luck. I was unable to delete the gmail account and re-add it because it said it was essential to the phone and I would need to factory reset it.
Question 1 - How do I go about backing everything up my SD card? Can I put what I want to save on my computer while I reset instead by plugging my phone in? I think I heard there is an app to send everything to the SD card. What is it?
Question 2 - What all will save to my SD card. I think Apps will not save, so I will write down which apps I want back and then just redownload them if thats the case. Will all my pictures and videos save? Songs? What will and what wont be able to be backed up?
Question 3 - How do I do a factory reset?
Thank you so much for the help but I think its time my phones get reset anyway. Lots of crap on there I don't really need but lots I really do.
