i remember hearing some people say that the incredible will have a weaker radio than the droid is it going to be noticeable? because i am considering switching to the incredible but this is one of the big issues i have been worried about
Can't you just stream internet radio?
so far the only people i've seen complain about it was engadget. and even then they said in the subway the inc got signal faster than the droid, so it's a mixed boat for sure.
i think in normal use, it won't be something you'll notice unless you have both phones side by side all the time
maybe a little but not as much as streaming music from Pandora or Slacker
Battery life hienarchy-
MP3 SD Card>/=Radio>>slacker/pandora
Streaming music from services such as Pandora and Slacker use a TON of data and you phone is constantly working HARD to process it all. In all seriousness I bet you would be lucky to get 3-4 hours before the battery was completely dead if you were constantly streaming music from Pandora. The FM radio would not be as intense as Pandora and would therefore use less of your battery. I would even go as far as to say you should get pretty close to the same battery life as if you were listening to music off your SD card.
I play poker at the casino often. When I go to play I like to listen to music during live games. I have a tour that I use currently. The battery dropped 67% over 6 hours. So I had to stop using it otherwise my battery would have died(I normally play 10hour sessions). Listening to the same songs gets old though. I only have about 150 songs. That is why the radio or slacker can be a nice change.
Thanks for the info.
i really like how this thread has taken the wrong meaning of the radio the OP was asking for and run with it.
