Results 1 to 2 of 2
    alear's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Mobile data connection not working
    Just putting this out there in case anyone else has the same problem. I received my phone and it works great with voice calls and wifi, however, the data connection through Verizon isn't connecting.
    In settings for "Wireless & networks", the "Mobile network" setting is checked but the whole thing is grayed out and it says "Turning on..." continuously.
    I went through 3 levels of Verizon support and then over to HTC support. At the end of several attempts to wipe the phone and check settings, HTC support rep said they had heard many reports of the same thing that day and the report was being sent to their research department.
    Overall, still blown away by the power and capabilities of the new phone and look forward to getting everything straightened out with the mobile data connection.
    Alex
  2. #2
    howarmat's Avatar
    Posts
    Global Posts
    27,765 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by alear View Post
    Alex
    saw another thread about this. Call VZW up perhaps and make sure the data plan is active
