Results 1 to 10 of 10
    Default Ring Scheduler
    Hi Everyone,
    Want to see if anybody out there has any good ideas for me. I am coming from a blackberry to the incredible and the one gripe I have is there is no way to have it automatically quite your notifications at a set time. I had the ring scheduler app on my blackberry. You could set it for a certain time and it would lower the phone and mute the notifications if you wanted it to, then in the morn restore all to normal. Well I downloaded the one for android and you can't separate the ringer sound from the notifications sound. I use my phone as my primary phone like lots of people and at night I want to hear it ring if there's an emergency but I don't want to hear emails dropping in at 2am. Any suggestions, besides do it manually. Thanks
  2. #2
    Default
    Check out Timeriffic for changing sounds at a certain time. Foxy ring lets you silence it from A to B so you could use that overnight and it allows you to input emergency contact numbers.
  3. #3
    Default
    I am using one called Quick Profiles. It doesn't set the profiles automatically, you have to do it manually, but it will let you separate the ringer and notification sounds
  4. #4
    Default
    Quote Originally Posted by Genetic_Bloom View Post
    Thank you SO much for the reference to Timeriffic! It's amazing!
    --FF
  5. #5
    Default
    Setting Profiles is the best that I have found.
  6. #6
    Default
    Settings Profiles is the BEST! I'm a former BB user too
  7. #7
    Default
    Does it let you silence some of the contacts individually or put to vibrate? without doing it for all the other contacts?
    I was able to do it with BB and it was very handy...............
  8. #8
    Default
    Quote Originally Posted by skagen View Post
    Setting Profiles allows you to do this to individual contacts and groups as well.
  9. #9
    Default
    Great thanks...............is it free.....I guess I can check that
  10. #10
    Default
    I checked and setting profiles doesn't do it for individual contacts.....it just changes the profile as a whole. I need something that I can set up individually......
