Results 1 to 7 of 7
    bseblman's Avatar
    Posts
    Global Posts
    138 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Can't get alarm to sound
    I have 3 alarms set up for various times of the day. Like my wakeup alarm is setup to 7:30 a.m. weekday mornings. I have the alarm sound as a music ringtone file, and I have it also set to vibrate. I did not hear my alarm sound off at all, and was not in a deep sleep. Has anyone else had a problem with their alarms not sounding? I didn't try it with a sound file instead of a music file, but that shouldn't matter I'm thinking. Any suggestions for a fix or for another alarm app that does work for sure? Thanks for your help.
  2. #2
    paul386's Avatar
    Posts
    Global Posts
    411 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    My alarm didn't wake me up this morning but when I tested it last night it worked fine. Perhaps I was in a really deep sleep and don't remember doing that (I do that often) but I don't remember doing it.
  3. #3
    bubbabeatz's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    i used mine today and it worked fine.
  4. #4
    jmcsmith's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    i had the same problem, had the alarm set for 6AM and it never went off, i was almost late for work.
  5. #5
    dmbhaggis's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    My built in one worked fine this morning but I downloaded Better Alarm to allow MP3s to be set
  6. #6
    mikedaub's Avatar
    Posts
    Global Posts
    123 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by jmcsmith View Post
    Same deal here. Mine never went off. Luckily, I was so antsy to get up and play with the phone, I was already awake. I just assumed that since I had my phone turned to silent for the night, that is why.
    bseblman's Avatar
    Posts
    Global Posts
    138 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I can't recreate the not sounding alarm with mp3 music file as I just tried my alarm like a couple minutes ago. Once without it plugged in and once plugged in, and the mp3 sounded both times. Not sure what was different that caused it not to go off this mornin' though. Very weird.
    Mikedaub: There's an option for the alarm to sound regardless of whether you're in silent mode or not. Look for it under Menu, settings when you're in the alarm program.
    Will look for that Better Alarm in case this happens again. Thanks for the 411 dmb.
