Results 1 to 4 of 4
    Default Screen Problem
    I looked around and haven't seen this mentioned.
    At first I thought I was imagining it but I am noticing it pretty often now. I will place the phone down and the screen will jump from my home screen to the last screen on the left without me touching it. Lately it's happening even more frequently and will happen even with the device in my hand but not touching the screen or the track pad.
    Is anyone else having problems with the Incredible screen changing by itself?
  2. #2
    Strygun's Avatar
    Posts
    Global Posts
    216 Global Posts
    Default
    Someone else recently posted on this, saying the same things you are. I can't find the post at the moment.
    It sounds like maybe something is in the optical tracker that is causing it to register false movements, like a piece of dust or something.
    -Strygun
    Former phone: HTC Droid Incredible
    Current phone: Motorola Droid RAZR M
  3. #3
    Default
    Here's the link I posted last night on this: HERE
    Follow me on Twitter: @DROIDBerryMA
    Default
    So I think I solved the problem........
    I went into settings>Language&Keyboard>Touch Input>Text Input>Calibration Tool
    Once I ran the tool it hasn't happened again. The only thing I can think of is that the screen was oversensitive and this seemed to have fixed it. I did this 2 hours ago and it hasn't happened once since then.
B
