1. Night Train's Avatar
    I'm sure I'm the only one that doesn't know this...but is the lower number, -90 stronger or weaker than the higher number, -80?
    What kind of number could one get standing right next to the cell tower?
    Thanks.
    05-03-2010 02:25 PM
  2. sum spicy rice's Avatar
    -80 is stronger than -90
    dunno about the cell towers question
    05-03-2010 02:28 PM
  3. MetaFan's Avatar
    I drove to my local tower last week and got a -50. I expected a -20 or so.
    05-03-2010 02:28 PM
  4. howarmat's Avatar
    lower the better
    05-03-2010 02:28 PM
  5. kdwg927's Avatar
    The best (lowest) I believe you can technically get is -50.
    05-03-2010 02:56 PM
  6. Super_Mario's Avatar
    I used to have -60 to -70 on my Berry and now I have no less then -95 in my home...
    05-03-2010 02:58 PM
  7. Jerry Hildenbrand's Avatar
    I think you're right. I can lean against the base of a tower and get no lower then -50.
    05-03-2010 02:59 PM
  8. Night Train's Avatar
    I guess what got me is the term "lower."
    I'm no math expert, but I do know that -90 is lower than -80. But I keep hearing that in terms of signal strength, the -80 is a lower measurement than the -90.
    I now understand that the closer a measurement is to 0, the stronger the signal will be.
    05-03-2010 03:45 PM
  9. doogald's Avatar
    Correct. The proper answer is that the higher the number, the better the signal. I guess you have to be a mathematician to understand that, though.
    05-03-2010 04:05 PM
  10. markhunsaker's Avatar
    Wow, thanks, so -50 dbm is good...I was always confused about that. Thanks Android Central...I was about to thank CB.
    05-03-2010 04:11 PM
  11. mike pertz's Avatar
    I'm at -89 and shows two bars 3g, and everything seems to run perfectly fast.
    05-03-2010 05:34 PM
  12. ecksit's Avatar
    Thanks.
    You will get a pretty much no signal standing next to a tower. I lived right underneath one (probably 200 feet away) for a few months and I never had service til I was about 1000 feet from the tower lol.
    05-03-2010 06:33 PM
