Page 1 of 2 12 LastLast
Results 1 to 25 of 30
    Default battery use shows android system using 65% of my battery
    this seems unbelievably high to me.
    display = 16%
    cell standby = 12%
    android live wallpapers = 7%
    under android system i see :
    htc checkin service
    network location
    account and sync settings
    accounts and sync
    settings storage
    checkin srvice
    setup
    rosie utility
    brcmbluetoothservices
    systemupdater
    sync feeds
    com.android.incrediblec
    android system
    vpn services
    settings
    htc widget download manager
    why is all this running and how can i kill it? have disabled bluetooth and vpn and am using advanced task killer...any ideas?
  2. #2
    Default
    what app tells you this info? sorry if it's off topic
  3. #3
    Default
    I'm in the same boat. Android system is chewing up the battery.
  4. #4
    Default
    Noticing the same thing here. Android system uses more battery than anything else. The core background processes running there must be incredibly draining.
    Edit: removed the duplicate info that you inclcuded in the op.
  5. #5
    yaemish's Avatar
    Posts
    Global Posts
    4 Global Posts
    Default
    Mine is doing it too. I even tried the program that kills processes.
    Default
    Quote Originally Posted by sum spicy rice View Post
    free app called anycut alows you to add shortcuts to anything you want. i added battery use
    Default
    ps i have been unplugged for 22 min and am now at 92% battery
  8. #8
    Jerry Hildenbrand's Avatar
    AC Cowboy
    Posts
    Global Posts
    5,821 Global Posts
    ROM
    Homebrewed
    Default
    That simply means that the Android system is 65% of what has been using your battery. Not that it used 65% of it. Ideally, Android system would be at 100%, everything else at zero.
    Default
    ok...well i am still frustrated im at 88% battery after 36 min of doing nothing
  10. #10
    Default
    Quote Originally Posted by bcat73 View Post
    You can view this info without installing anything to do it.
    It's under: settings>about phone>battery>Battery use
  11. #11
    Default
    Quote Originally Posted by Peanutbutter_N_Jelly View Post
    thanks! will try this later to see what my battery is doing
  12. #12
    VZWBB's Avatar
    Posts
    Global Posts
    309 Global Posts
    Default
    Mine was showing android was using 92% of the battery lol.
    I don't know what it means as far as battery life goes, but for me, I can make it a whole day before having to be plugged in. I think some freak when they see the battery down past half way....doesn't mean its dead....just low.
    Kinda like a car maybe....like you get 200 miles till your guage reads 50%, and then another 120 miles and it reads empty. Where did the 80 miles go?
  13. #13
    Default
    Android System is your entire OS. You can't kill it. Like it was stated above, ideally you would want Android System to be 100% of your battery consumption if you're not using anything else (standy by) will also be on there.
  14. #14
    Cory Streater's Avatar
    Forums Emeritus
    Posts
    Global Posts
    13,813 Global Posts
    Default
    And for those of you that start killing processes with task managers: Before you start new threads about phone crashes, lock ups, force closes, and other weird & random problems, please remove your task manager and see if those issues go away.
  15. #15
    Default
    I've noticed my battery life has gone up tremendously since the first day. Give it a few days and it should increase.
  16. #16
    Default
    Wow, this may be premature, maybe someone can confirm this. I had the Weather/Clock widget on my homescreen and got around 86-92% battery used by Android System. After removing the widget, Android System is taking 16% of the battery and my phone is still up and running.
    This is the first time that "Phone Idle" is actually using a higher percentage than Android System!
    Edit 2: Yeah, removing the weather/clock widget drastically reduced the power Android System was using.
  17. #17
    VZWBB's Avatar
    Posts
    Global Posts
    309 Global Posts
    Default
    The weather clock widget is too cool to remove....sacriledge! :P
  18. #18
    Default
    funny mine is always "cell standby" and "phone idle" what exactly are those and anyway to reduce those?
    ~Matt
    Rooted Galaxy Nexus & Rooted Nexus 4
    Rooted Asus Transformer
    www.twitter.com/howarmat
  19. #19
    ncbryan's Avatar
    Posts
    Global Posts
    341 Global Posts
    Default
    Today is my first full day of use of this phone. I got it in my hands last night and told the guy at the store to plug it in before I picked it up. I used it last night setting everything up on it. Plugged it in last night. Hasn't been on the charger all day and it has been used I would say moderately throughout the day and I still have about 65% of my battery left. Things I did to improve battery life (can also be seen in Cory's batter life post on page one of the forum) are:
    1. Turn off WiFi when you aren't using it.
    2. Turn off Bluetooth when you aren't using it.
    3. On your weather apps like Weatherbug, turn off GPS support.
    4. Uncheck the box for Use GPS satellites in Settings/location. If you need to use the GPS function, turn it on, but make sure you have your phone plugged into a car charger.
    Read Cory's full post on saving your phone's battery and I don't think you will have an issue with battery life anymore!
  20. #20
    Default
    think logically. if you're seeing "android os" using 90% (or whatever) or any other system process using 90%+, its because you're not using anything else. SOMETHING has to be using the battery, so whatever is running is being reported as using the dominant share of the power...
    its like reporting that you've been sleeping 90% of the day when you're hungover. it may be true, but the percentage is outrageous because that's the only thing you've done all day...
  21. #21
    nalpakj's Avatar
    Posts
    Global Posts
    175 Global Posts
    Default
    Have all of you read the battery sticky ('Battery Life Not Lasting')? I was having pretty poor performance at first, then changed this setting and have seen a pretty big difference. I've been unplugged for about 7 hours and was thrashing pretty hard on it earlier (internet access, installed a few things, uninstalled them, etc) and still am at 70%.
  22. #22
    Default
    Quote Originally Posted by indianajonze View Post
    I'm sure most of us understand that already. Ideally, the "SOMETHING" that I want to consume the highest percentage would be Cell standby and Phone idle, especially when I have the phone asleep in my pocket.
    Having Android System taking a large percentage means that the phone is using quite a bit of battery doing something other than idling while it's supposed to be idle. Low and behold, it seems that the weather/clock widget was the culprit in my case.
  23. #23
    Default
    The Incredible comes with a smaller than usual battery (1300mAH), that is the same size battery that comes on the smaller to Android phones such as the Cliq or MyTouch 3g that have slower processors and use less battery power to run.
    You can try lowering your screen brightness and removing widgets. For example, the Engadget widget uses alot of battery. Other than than, you can carry around an extra battery.
  24. #24
    Default
    Quote Originally Posted by seucode View Post
    even with those being the most used on my device i am only going to get 20 hours with the 1750 battery probably. and that also means in NOT using the phone much which is true. so its give and take for sure
    ~Matt
  25. #25
    Default
    Edit. will post in a min
