Results 1 to 9 of 9
- 05-04-2010, 11:40 AM
Thread Author #1
- 05-04-2010, 11:48 AM #2
(I don't think you can, unfortunately...at least not that I can figure out. On past phones what I've done is just create a second speed dial shortcut and put in the pause and password and just not use the default speed dial.)
EDIT: I figured it out...
Go to your home screen, hit Menu > Settings > Call > Voicemail settings > long press on "voicemail number" and then edit the voicemail number there. I assume that that will change the speed dial number (though I haven't checked myself).Last edited by mr88; 05-04-2010 at 11:51 AM.
Matt
Using: HTC Incredible
Formerly: BB Storm
on Verizon Wireless - 05-04-2010, 12:12 PM
Thread Author #3
- 05-04-2010, 12:17 PM #4
When you edit your voicemail, AFTER the *82 that is already there put a comma (pause) and then your password. Works like a champ!
- 05-10-2010, 11:08 AM #5
anyone know of a way to override the face sensor? seems to me that my password isn't dialing until i pull the phone away from my face. i think when the sensor blacks out the screen, it prevents any dialing.
- 05-10-2010, 01:08 PM #6
- 05-10-2010, 01:16 PM #7
I would think if you could override it, it would be for every call dialed, not just this one, and that might prove annoying as well.
I had this happen to me the other day too. I simply pulled it away from my face, screen came back, it dialed password automatically, and I put it right back to my ear.htc - Incredible - 05-10-2010, 01:22 PM #8
- 02-21-2013, 04:38 PM #9
Reply
