or if you are plugged in, and the notification appears up top, pull down the notification bar, and the alert will say "click to disable usb debugging", click it and it will automatically bring you to the menu. You don't need it to be on unless you are using your phone to develop and debug apps. On rooted devices, you will have that on to use adb shell to do some commands on your phone through your computer.
