1. markhunsaker's Avatar
    My phone used to vibrate on normal and vibrate on incoming notifications. I do use Handcent SMS and GMail. I hear the audible notification but no vibrate. I have checked the settings within GMail and Handcent. I have the correct settings to have it vibrate always. But no vibrate. It does vibrate in other programs, like when I turn the volume down to vibrate settings, it vibrates. I have tried rebooting the phone...nothing. Anyone?
    Thanks!
    05-07-2010 05:54 PM
  2. bdizzel1982's Avatar
    Thanks!
    have you tried checking the settings in the default messaging app to see if it is some how effecting the other two? If all else fails just do a hard reset.
    05-07-2010 06:10 PM
  3. markhunsaker's Avatar
    I did check all the settings, including the default messaging app. I did a hard reset, and that fixed it. Thanks to google and backup assistant...I'm good.
    05-07-2010 07:43 PM
  4. sum spicy rice's Avatar
    this is a bug. next time download an app called "Sound Manager" and then do the settings on that app that say "vibrate on notification". u can delete the app afterwards if u want. it works. it's in the Tips and Trick section
    05-07-2010 08:04 PM
  5. kentoe's Avatar
    hah you beat me to it this time sum spicy rice! thanks!
    05-07-2010 08:08 PM
  6. jjordo1's Avatar
    I had the same issue with mine sound manager fixed it thank you
    05-31-2010 09:16 AM
  7. SirChazwell's Avatar
    I'm just commenting to state I had the same issue and I had to do a hard reset. Sound Manager is great because having to set up my "Scene" again was far too tedious for me. Ha.
    06-01-2010 12:37 PM
