1. srvac's Avatar
    I may be slow, but I can't figure out how to silence a notification when I get a text. When I do, I have a 30 second ringtone which I use to increase the chance I hear it if I don't have the phone on me. But, there are times where I have it right next to me and would like to silence it rather than play the entire ringtone. The only thing I've been able to do is open the response box and type and send something quickly. Any ideas?
    I do use Handcent as my SMS app
    05-08-2010 04:49 PM
  2. zdsa1021's Avatar
    I would like to know the same thing. I also use Handcent and have the same problem.
    05-08-2010 05:50 PM
  3. krelvinaz's Avatar
    I just hit the close button and it stops right away.
    The sound I am using is a modified version of the Crazy Apring tone. I took it and increased the volume, and made it repeat 6 times. I don't miss my SMS pages now.
    Hmmm... just remembered. I am using a new app that adds to the default one. In the default Messages app, I have notifications off.
    The other app is called SMS Popup and I have no problems clicking on the Close when it fires off.
    05-08-2010 07:09 PM
  4. StayFly's Avatar
    yep need to know info, i know when you pull down the notification bar it silence it but why can't i just press the power or volume button for it to silent like my storm?
    05-08-2010 07:10 PM
  5. TreoDru's Avatar
    I would also like to know how to Interrupt or silence notification sound for SMS. anyone? Bueler, Bueler, Bueler
    10-13-2010 06:42 PM
  6. Kyle Gibb's Avatar
    Try hitting the back button, I think that might work.
    10-13-2010 07:43 PM
  7. rpfarrah's Avatar
    Because its NOT a storm.
    10-13-2010 10:19 PM
  8. clabbin's Avatar
    This isn't so much an issue or bug as it is something that's not been implemented in most, if not all android devices but we will go ahead and call it an issue. I work for VZW and my manager actually came to me with this issue and wanted me to look into it. I tried on my Dinc, a droid x, a samsung fascinate and a droid. None of them would silence an SMS notification by hitting any physical buttons or soft buttons. Customer service over the phone didn't even have any info on it. Best recommendation is to just use a short tone. I really don't see this being fixed or implemented any time soon to be honest
    10-14-2010 11:43 AM
