Results 1 to 10 of 10
    Default Speed Dial Settings Suddenly Disappeared
    Has anybody else had this problem? This morning, I went to make a call using speed dial, and all of the settings had disappeared. I had been using speed dial for the past week or so without any problems. Is it possible that I accidentally did something to wipe out all of the settings? I didn't fiddle with the phone settings, so I can't imagine what it might have been.
  2. #2
    bss
    bss is offline
    bss's Avatar
    Posts
    Default
    I too have experienced this numerous times. Seems to happen at random - I'll go to hit a speed dial that I previously set up and it will not work, so I look at the settings for speed dial and only 2 of the 5 numbers are still there. Really weird. Going to try a factory reset and see if that helps.
  3. #3
    Default
    I have had the same issue a couple of times. Just happened again today! Any info would be great! Thanks!
  4. #4
    Default
    I'm having this issue now too. Any solutions?
  5. #5
    jas o's Avatar
    Posts
    Global Posts
    760 Global Posts
    Default
    I have had this happen too a couple of time. No idea why.
  6. #6
    Jamboaz's Avatar
    Posts
    Global Posts
    57 Global Posts
    Default
    I'm seeing this constantly on my Evo. I can go so far as to set them up, make a call or two, go back to the speed dial setting and several are missing. This is very annoying
  7. #7
    Keldog's Avatar
    Posts
    Global Posts
    256 Global Posts
    Carrier
    Stock 2.3.4 - 4.08 build
    Default
    Happened to me a couple of times.. I just end up resetting them and they work fine for a while. I always have voice dialing as a backup.
  8. #8
    HawaiianLaker's Avatar
    Posts
    Carrier
    OEM Unlock + Root
    Default
    I have had the same issue... sort of. when i try to use speed dail, i press and hold and nothing happens but if i delete the number i just pressed and press and hold again it will work. kinda weird. rooted on skyraider 3.5
  9. #9
    Default
    Had this problem too and found it was caused by Skype. Try uninstalling it.
  10. #10
    Default
    I'm having the same issue - my speed dial on my Epic 4G had been working fine, and now it seems randomly different speed dial settings are deleted (for example, the person I assign to #s 3 and 9 disappear, but the others remain -- then another day #5 disappears, etc.). I do not have Skype installed.
