1. zini316's Avatar
    I understand each block represents 10%, but is there away to actually show the exact %?
    05-10-2010 07:15 PM
  2. Jared DiPane's Avatar
    Unfortunately I think it is in the Android Os to only report in % of 10. Even on ROMs (not for the Incredible) that have batt % displayed it displayed in 10's.
    Not sure if there are any widgets or apps that read this more accurately but I havent seen one.
    05-10-2010 07:16 PM
  3. zini316's Avatar
    Thank you for the quick reply Jared.
    05-10-2010 07:17 PM
  4. nightfishing#AC's Avatar
    Battery Left is a very useful widget. will show you % and est. time remaining.
    05-10-2010 07:18 PM
  5. howarmat's Avatar
    i agree battery left is pretty damn nice.
    several other apps will show the % in full in the notification bar but you cant get rid of the stock battery icon
    05-10-2010 07:44 PM
  6. markhunsaker's Avatar
    I like the face it doesn't show me. I have deleted all my battery widgets...I don't compulse over the battery left.
    05-10-2010 07:50 PM
  7. YourMobileGuru's Avatar
    Battery Status Pro will give you a little white battery icon in your notifications tray with the battery percent in it. I've been using it since launch and it works great.
    05-11-2010 03:19 AM
  8. dgalanter's Avatar
    You can plug it in and click the clock/weather home screen widget and it tells you how much is left on the battery along with other info.
    05-11-2010 06:37 AM
  9. indianajonze's Avatar
    what he said. just click on the clock/weather widget if you're using it and it shows the batt% in the lower right corner
    05-11-2010 08:55 AM
  10. iowabowtech's Avatar
    Many good ideas already presented. There are many free battery widgets/apps in the marketplace.
    05-11-2010 09:04 AM
  11. howarmat's Avatar
    in the default clock/weather app i see nothing about battery %
    05-11-2010 09:21 AM
  12. Odin3's Avatar
    I don't see the percentage either. Can someone please clarify?
    05-11-2010 10:17 AM
  13. kdwg927's Avatar
    If you click on the clock widget when the phone is plugged in, it will show the battery %
    05-11-2010 10:32 AM
  14. howarmat's Avatar
    ah i dont have it plugged it....stupid thought here, why would you really care what % you are at if you are plugged in and charging. i only want to know how much is when UNPLUGGED lmao
    05-11-2010 10:50 AM
  15. atlbuc's Avatar
    I use the HTC Battery widget from the Market, small lightweight and just what I need.
    05-11-2010 11:08 AM
  16. RayStinkle's Avatar
    you should install that battery widget, and put it on your homescreen, because not only does it give percentage, but it also gives you the voltage of the battery. i find that monitoring the voltage is much better than looking at the percentage. i know at 4.167 V my battery if fully charged, etc. and just watch it drop thru the day.
    05-11-2010 12:10 PM
  17. atlbuc's Avatar
    Yea the HTC Battery Widget gives you the Voltage and Temp, works flawlessly for me.
    05-11-2010 04:30 PM
