Results 1 to 4 of 4
    Default Incredible USB charging problem - cycles
    Recently when I plug my Incredible into my computer to charge it starts cycling the charge options screen. If I enable disk drive while plugged into a computer it keeps just repeats the "open files" screen on the computer. If I choose "charge only" it flashes in the notification area.
    Any feedback would greatly be appreciate
    TommyRox
  2. #2
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Default Re: Incredible USB charging problem - cycles
    Never seen that before. What's Flashing in the Notification area when charging?
    Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig.
    Sorry for the long delay - it was the cable - go figure
  4. #4
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Glad it was an easy fix!
