Results 1 to 3 of 3
    ulnek's Avatar
    Posts
    Global Posts
    585 Global Posts
    Default Control Strip = Data Connection button
    how do i make the the "3g" button which switches data connection on and off on the control strip widget to work again? the wifi button works fine and the gps button changed a bit that it opens the entire list of gps possibilities but the data connection is completely non-operational. even tried two other widgets that did the same thing before and both also don't work now. i'm sure i'm not the only one who had the problem, so please share your solution as i use that button as often as i use the vibrate/silent button.
    Motorola Razr Maxx
  2. #2
    iBowToAndroid's Avatar
    Posts
    ROM
    stock
    Default Re: Control Strip = Data Connection button
    Is this something that came in the latest Gingerbread update, or are you using a 3rd party app like Extended Controls?
    vanquish (stock rooted)
    d2spr (CM 4.2.2 nightly)
    manta (stock rooted)
    Follow me on Twitter
    Email/GTalk
    Google+
  3. #3
    I use LauncherPro Plus and from LP you do not have access to the Sense version of the 3G toggle button so I have had to use other toggle widgets to turn the 3G on and off, after I forced the update a couple of months ago to Gingerbread I went through multiple toggle widgets and none of them worked on GB until i found Widgetsoid. Widgetsoid allows you to set up and configure any kind of widget you want, there are many different settings and this can be confusing but on the mobile data widget I was able to set it up as a rooted device and it works perfectly.
    Hope this helps.
