some seem to have issues without a SD card. Shouldnt be a problem since VZW gave you one though. Just load up the 2 GB card even if you dont plan using it really
Not everybody got a free sd card with their DI. But the little ones aren't very expensive so if you're running into trouble it's not a huge investment to fix.
