Results 1 to 10 of 10
    sillyshyme's Avatar
    Posts
    Global Posts
    48 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default using doubletwist to sync
    I added some video's all in the same format and codes but only like 2-3 did not show up and my memory card is not even full. Also using the doubletwist mobile app none of the music or videos appare?
  2. #2
    BigpappaJ's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Thats weird... I am using it and everything I have placed and synced to the phone shows up... including podcasts
  3. #3
    syrguy1969's Avatar
    Posts
    Global Posts
    725 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I have the exact opposite problem...Doubletwist is importing EVERYTHING from my computer to my Inc. I'm looking for how to limit what goes over. I specifies (what I thought) the sources but have a card fill of thousands of images and hundreds of songs I hadn't intended on importing!!
  4. #4
    bcp0809's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I am not so sure this program should be out of beta. My sync issues are close to yours - and it takes a good minute for my Mac to open the application.
  5. #5
    Bmilano3161's Avatar
    Posts
    Global Posts
    146 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I downloaded both doubleTwist and a few other music sync apps; all without much luck. I have a 16GB SD card that is totally empty. I have about 5000 songs in my iTunes folder (mainly from CDs but also from Limewire and other sources); none of these apps I use is able to transfer more than 150-200 sogs to my MUSIC folder. And none of them transfered any of my podcasts
    Any ideas what the problem could be?
  6. #6
    groundkontrol's Avatar
    Posts
    Global Posts
    69 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by slider9499 View Post
    Try iSyncr. It's a paid app. I haven't tried it yet but I've heard good things about it.
  7. #7
    BSG75's Avatar
    Custom User Title
    Posts
    Global Posts
    1,059 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOKP
    Default
    Ate you sure you synced til the sd card? It only reads media I the sd card.
  8. #8
    I am138's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM7 nightly#77
    Default
    Get Isyncr. Works much better than Double Twist.
  9. #9
    srvac's Avatar
    Posts
    Global Posts
    159 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I'm glad it isn't just me. I've had problems with it saying that I need to upgrade my iTunes songs to iTunes Plus and many songs aren't transferred. But all of my songs are upgraded and not DRM protected. I'll try iSyncr too
  10. #10
    kcannon's Avatar
    Posts
    Global Posts
    42 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Is it possible to sync with Isyncr and play music with doubletwist?
