Results 1 to 13 of 13
    Default htc battery
    any tips on getting more out of the hts incredible battery life?
  2. #2
    Default
    As with any smart phone the battery life is something that needs improvement. However, I purchased the ZAGGsparq 2.0 as my new source of keeping my new Incredible charged throughout the day. Probably now what your looking for, but I am hoping it will help me out.
  3. #3
    Default
    Has anyone gotten any information on when the 3500 mAH battery for the incredible is expected to be be out? 130+% more juice sounds so sweeet.
  4. #4
    Default
    so far, i've let the battery fully drain twice, and have since followed everyone's advice for charging it when its convenient. turn off the wifi and gps when not needed, and you should be ok. the only thing that tends to drain my battery life is downloading tons of apps at once (i came from a bb curve 8330, so i'm going in a bit app crazy!).
  5. #5
    bigslam123#AC's Avatar
    Posts
    Global Posts
    1,278 Global Posts
    ROM
    Stock
    Default
    Quote Originally Posted by fenderstrat1184 View Post
    As someone who came from the BB Storm1, I understand where you are coming from about the apps. That being said, be careful. As the Android Market is open source some apps can be malicious. Also some apps may not be coded very well and can cause battery drain on your phone, much like the BB and memory leaks. Download apps you trust, and always make sure to check out the reviews of an app before you download it. This has saved me from downloading a bad app many times, even from trusted sources.
  6. #6
    Default
    Quote Originally Posted by dscribe View Post
    I haven't heard any news yet, only holdup I can think of would be developing the back cover since it's likely to be the same battery as the one for the Eris.
  7. #7
    dgn37's Avatar
    Posts
    Global Posts
    3 Global Posts
    Default
    There is a great link for improving battery life regarding wifi, network settings, brightness, background, task killers, etc ... try here ... http://www.androidcentral.com/keepin...-android-phone ... hope that helps! Worked great for me. I can get about 2 hours of talk time, 20+ texts, 20+ emails, and make it home from work.
  8. #8
    Default
    Also, one thing to also think about after you read that link http://www.androidcentral.com/keepin...-android-phone is that some developers submit apps that are not battery friendly when kept running in the back ground even with the "first in, first out" process of memory caching within the OS of the HTC Incredible. Be weiry of what applications use a lot of battery or actually need to be running contantly. like a widget or something for that app you may have downloaded.
  9. #9
    Thumbs up
    Just stick with the battery. From normal charging, my battery life has increased from a "WTF!?" to 18 - 20 hours of light usage.
    I suppose to quantify light usage, I mean; a couple phone calls, a number of text messages and some web browsing to read some news or search Google for a factoid.
    Of course some apps like this Simpson's jigsaw puzzle, that I fully enjoy, destroy my battery in just a few minutes, and navigation isn't the lightest but general usage is up to a full day for me.
  10. #10
    tony bag o donuts's Avatar
    Resident Ringtone Maker
    Posts
    Global Posts
    6,872 Global Posts
    ROM
    BB JB
    Default
    Quote Originally Posted by ericsapackerfan View Post
    welcome and just look at the sticky on top of this forum.
    How to install an Invisible Shield
    3rd GN 2-29-12
    2nd GN 1-1-12
    1st GN 12-17-11
  11. #11
    Default
    I just ordered Seidio's 1750mAH battery along with a charger to charge my extra battery and my phone at the same time. Will guarantee I always have a charged battery at all times. I'm down with that.
  12. #12
    lcsglvr's Avatar
    Posts
    ROM
    stock
    Default
    1750 does me fine. It should do you well unless you are an extreme heavy user (e.g. surf web for hours and hours at a time, download like crazy, 100% brightness, etc...). You should just get that, unless you plan on hiking for a week and can't charge your phone. Other than that, why get a battery that can last several days? Everyone has access to a charger AT LEAST at night. Plus, with the 1750, you don't have to get a replacement backing.
  13. #13
    Default
    I'm on Day 4 with my 1750 Seido. Yesterday had pretty good battery life. Still waiting to see how this battery performs after its cycled a few times.
