Strange happenings ...
wryun
105
I have been using my Droid Incredible for about an hour and a half straight. Twice during this time I have seen an HTC logo pop up, my screen then goes dark, and a spinning wheel shows up for about 10 seconds. After that, my screen goes back to notmal. Have any of you seen this before?
rader023
125
Ive had that about six times. About 4 in the same day. I am guessing sense is resetting for some reason.
nygolfmc
Active member
May 4, 2010
27
Mine just started doing it, but I figured mine was because I installed TaskPanel X and set it to only autokill the calendar. It is really strange, but I have had the same thing happening.
anon(30569)
54
Hm. I agree with radar023, it sound like the UI resets :/ Picked up mine about 3 hours ago, its got some hard usage in that time- downloaded about 40 apps,wallpapers,live wallpapers, games, all that and I havent seen any of that i hope it stops for ya!
SpartanDroid
159
I really have never seen that. I have had my phone since launch and have never had that problem before. Sometimes things will freeze but all that ends up happening is a force close. That is very strange.
bespinct
832
18
I've had mine since launch too. I have seen it every so often, usually when moving from GMAIL back to the home screen. Historically, I haven't been archiving my mail. I went online to archive everything and I haven't seen it since.
I was thinking that it may be the system clearing memory. It's never longer than a second or two, so I haven't really worried about it.
Steve in CT
wryun
105
Never seen anything like that. Have you downloaded some kind of funky app?
The only thing I think changed before it happened was installing HandcentSMS. I do not use any task killers, so I know it's not that. I just removed HandcentSMS so I will see how my phone does now.
Thanks.
wryun
105
UPDATE:
I don't want to jinx it (knock on wood) but ever since I removed HandcentSMS I have not had the "htc" logo reboot problem.
lcsglvr
190
3
I have had it in RARE cases. However, once I downloaded TaskPanel and set it to auto-kill the calendar, I've been having it more frequently.
Upstreammiami
2,098
482
this happened to me a couple of days a go.. but i remembered it happened while opening an app and also another one clicking on a link... im guessing it happens while your going to run something
rugbyua9
457
22
I've had it happen to me too... only when i am doing something processor heavy on the phone (installed the program, clicked to run it immediately after installing, it didn't open up and opened up another program which caused my phone to lag). My guess, is its a fault system that resets the UI when the processor is overrun to maybe save battery or keep from freezing/crashing in a more ugly manner?
Just my $0.02
Revolutionary
876
21
This happens when you kill a process (or it fails) that is being used by the UI. So if you are running the calendar widget, for example, and you autokill the calendar app, you will trigger a UI reboot (which will just relaunch the calendar app for the widget, so don't bother autokilling the calendar if you want to use the widget!).
For wryun, I'm guessing Handcent was interacting with a widget? Like perhaps the messages widget? Perhaps you had a conflict where both the stock messages app and Handcent were tapping the widget? Dunno about that one -- sounds like instability in Handcent was as far as you can go with it. I'm running Handcent and have used it to replace the stock app for the messages widget, and I haven't had a single crash or force close.
fuzzy#AC
7
my phone reset today, first time i think, also
shut it off last night to charge and when i woke up it was on...strange
i've had it since launch and it seems to be getting really buggy the last week or so
wryun
105
Here I am 5 days after removing HandcentSMS and I have not had one single reboot/original problem I posted about. I believe HandcentSMS is the culprit. Which is a bummer because that app rocked. I hope they come out with an update soon to fix the issue.
rpfarrah
940
15
Any new or recently updated apps?
That's too bad. I've had no significant issues at all with Handcent - seems to work great. the only thing I've had a challenge with is sending pictures via the app. But it could also be operator error.... :D
aplittle
129
I have not seen this on mine. I have been using it heavily since I got it and have not had any issues. If I do see it I will try to figure out what I did/changed before it happened and post it here.
Aaron
