Blahzee#AC
It's been almost 3 hrs since I've taken it off the charger and the 1750 mah battery is down to 80%. Is that good for this battery?
That would depend on a few things, is this after your 1st charge, if so make sure you follow the instructions on how to charge the first few times and discharge. My 1750 has gotten better over the last few weeks, it was really crappy right after the froyo update. That was just a coincidental I believe because I was playing with it to much. With normal usage I can get a full day out of the 1300 and the 1750.
Went through the battery reconfig on Friday.
Is there a list of known battery killing apps? Something is killing mine
Instead I want to share a fluke that happened to me that i think significantly improved my battery.
I use my phone as my alarm so it is on and charging all night. One night I decided to shut off and charge overnight to get as full a charge as possible. Well I was so tired that when the little reminder comes up asking if you want to turn it off, I did nothing and plugged it in and crashed.
The next morning when I went to turn it on, it was still in the suspended are you sure you want to turn off screen. So it charged all night with this reminder screen up and still on.
I shut it off and turned it back on. Not sure if this is what caused it or not, but ever since this, I am getting STELLAR battery life. I have also noticed my awake time seems to be significantly less as well.
With light use I can get 24hrs or more, with moderate use a good 20hrs and with heavy use easily 12-15hrs.
VZW is replacing my X with an Incredible tomorrow. I hope that I am doing the right thing. Anyway, does anyone have any input on the 2150 battery available from VZW, such as battery life and added bulk, and is it worth it to switch to this battery?
