Results 1 to 6 of 6
- 06-25-2010, 01:36 AM
Thread Author #1
Bump charging problem...
I use the sedio 1750 battery.
The last 2 days I've had a weird experience when bump charging.
I charge all night with the phone "on", and in the morning, pull out the charger, turn off the phone, and then plug the charger back in for about 30 minutes (or when the light is green again).
When I remove the charger and turn the phone back on, it shows there is ZERO percent battery life, and it turns off within seconds.
Then I recharge, and the thing will last me 13+ hours.
But, what's with the 0% charge thing? What am I doing wrong?
I guess from now on I'll just keep the phone on while charging and won't bump charge.
confused. - 06-25-2010, 07:14 AM #2
FWIW, I don't do the hokey pokey charging thing. I charge mine all night, get up and answer email or whatever, then put it back on the charger while I get ready for work. It's always green inside of a half an hour or so and ready to go. With the 1750 battery I get a good long day's use.
...my $.02 - 06-25-2010, 09:18 AM #3
Is the extended battery larger than the stock one? By larger, I mean will it need another battery cover plate or will it fit under the regular one? I haven't had a chance to go look at em yet...
- 06-25-2010, 09:40 AM #4
- 06-25-2010, 10:07 AM #5
- 06-25-2010, 10:28 AM #6
Reply
