Results 1 to 13 of 13
- 07-23-2012, 03:15 PM
Thread Author #1
Droid Incredible Stuck On HTC Incredible Screen. PLEASE HELP
Okay so i'm new to all of this and I have looked around but all of the similar posts are results from flashing roms and stuff.
Today I did a factory reset because I had MIUI on my phone but it was messing with my text messages and it was important that I get them properly so that's why I did a hard reset.
So after I wiped it, I restarted it and it just stayed on the white HTC Incredible Screen. I've pulled the battery and it still only gets to that screen.
I have held down the volume button and the power button and i can get to the hboot screen but I have no idea where to go from there to make things work right.
I don't know if this is necessary at all but when i get to the hboot screen this is what is at the top
INCREDIBLEC XC SHIP S-OFF
HBOOT-0.77.0000
MICROP-0417
TOUCH PANEL-ATMEL224_16ab
RADIO-2.15.00.07.28
Mar 23 2010, 19:36:32
And then it has
Hboot, the volume button instructions, fastboot, recovery, clear storage, and simlock.
Please help me! I really hope it isn't bricked because I don't have a backup phone or anything. :/
- 07-23-2012, 03:27 PM #2
- 07-27-2012, 06:44 PM
Thread Author #3
- 07-28-2012, 07:25 PM #4
Re: Droid Incredible Stuck On HTC Incredible Screen. PLEASE HELP
I would load a different ROM. Downoad it and put it on your SD Card them flash it in recovery.
My suggestion would be CM7's latest nightly for the DInc. Also download the GAPPS and flash it in recovery as wel to get the Market/Play app.Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig. - 07-29-2012, 11:56 PM #5
I actually just reread your post. A hard reset on a rooted phone isn't the same as on stock. When you reset stock it just returns the phone back to what it was new. When you do that to a rooted phone it removes the from also. If your in recovery you're not bricked, you just need to flash a from. That's why your stuck on the boot image
Sent from my LG-VM670 using Android Central Forums - 07-31-2012, 03:22 PM
Thread Author #6
Kay so i;ve downloaded a new rom to my laptop but when i plug my phone into it it, to put it onto the sd card,it does not show up, i know it needs to be "mounted" in some settings, but like i said before, its stuck on the white htc incredible screen..so i can't exactly change the mounting settings.
- 07-31-2012, 04:49 PM
Thread Author #7
- 07-31-2012, 07:45 PM #8
Cool. Sorry I didn't see your last post till now, but glad to see you got it straight.
Sent from my LG-VM670 using Android Central Forums - 08-20-2012, 02:15 PM #9
- 08-20-2012, 08:26 PM #10
If you are rooted and can get into recovery - Download a new ROM, like CM7 and flash it.
If you're stock and not rooted then do a factory reset and it will reset your phone to Out of the Box settings.Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig. - 08-21-2012, 09:33 AM #11
- 08-21-2012, 09:37 AM #12
- 08-21-2012, 09:38 AM #13
Reply
