1. vatsyk's Avatar
    Seems like Verizon has solved the call waiting switching problem. Before I had this: When talking with person A, the person's B call comes in-muting the person A, if I hit " answer" the phone used to freeze and hung both A & B, if I hit " ignore " to get rid of person B, I could not return to person A because somehow DI hung up on person A.
    Anyone had similar difficulties before and how it is solved ?
    07-04-2010 02:08 AM
  2. CRKhead's Avatar
    Wait... Your saying the problem is solved, and you describe what the problem is, but don't describe what it does now that makes you say it's solved, then ask if someone knows how it's solved...
    Can you solve this post for me? you can now hit answer and switch between calls just fine, or no?
    07-04-2010 05:23 AM
  3. vatsyk's Avatar
    Yes, you can now hit answer and switch between calls just fine.
    07-04-2010 01:37 PM
  4. Trophias's Avatar
    uh....correct me if I am wrong...but, you could always do that. Even with 1.5....
    07-04-2010 04:42 PM
