1. IncrediBry's Avatar
    I just got the 3500 last night and had a question about battery temperature.
    I have the "Battery Indicator" App which I believe is very useful. Shows you when you unplugged, what percentage you were at when unplugged and the temperature of the battery.
    I noticed the same thing with the stock battery, the 1750 I had and with the beastly 3500 I have now.
    When I'm on the train in the morning and have "heavy" usage ( pandora, stock music, internet, etc) the temperature goes from about 88 to over 100 degrees.
    During this time the battery is drained like wildfire and I can't help but wonder if there is a problem with my phone that makes the battery increase in temperature which in turn causes it to drain quicker.
    Does anyone else notice the temperature of your battery during moderate / heavy usage?
    07-27-2010 08:06 AM
  2. NIKSTORM's Avatar
    This has been discussed many times in many places, but.....yes this phone gets very hot very quickly. When I use Pandora or navigation it gets super hot. I don't worry much about it because if the phone burns out I will just get a replacement. I just hope that your new 3500 doesn't burn out because I don't know what the return policy is on it. Good news is that since the phones release this has been a discussion and only one or two people posted that they burned out the phone. You are not alone.
    07-27-2010 10:12 AM
  3. brina042's Avatar
    With heavy usage, my 1750 gets up to 105-110...that is normal. As long as it doesn't get up to 140, you will be ok
    07-27-2010 10:30 AM
  4. NIKSTORM's Avatar
    I wanna get mine up to 200 just to see if I can.....
    07-27-2010 10:34 AM
  5. brina042's Avatar
    Jaredshoes likes this.
    07-27-2010 10:44 AM
  6. NIKSTORM's Avatar
    Really was that necessary? What if I want to get my phone up to 1000 degrees am I still a *****? It's my phone....I paid for it.....if I want to throw it in a f-ing fire I will. Who asked you anyway?
    07-27-2010 10:58 AM
  7. bobnfloyd's Avatar
    So... ignoring the off track nature of the last few messages, I've noticed that when using navigation and charging using a OEM ATT micro-usb cable that the battery temp will get into the 105 degree F range and then I'll notice that the phone is no longer charging. Is that normal? The ATT charger is a 1Amp charger so the phone does register as a AC charging while I'm using GPS and trying to charge the phone I will look at my BatteryLife widget and it will register as being in a "Overheat" state (and it seems that the phone is not charging). I'm not sure the application knows what temp is acceptable and in spec for our Droid Incredibles, does anybody have any insight as to both the spec'ed battery tempreture range allowable, and why my phone stops charging? Thanks in advance!
    07-27-2010 01:06 PM
  8. rpfarrah's Avatar
    Just surfing these pages and I'm at 98 degrees. Using the Seidio 1750. After a little more surfing I'm at 103.
    07-27-2010 02:12 PM
  9. Saiyajin's Avatar
    I've had one instance where using Google Nav in the car while charging I hit over 118 or so. Spare Parts called overheat, so I unplugged it, let it cool, and when I plugged it in it was fine.
    07-28-2010 01:53 AM
  10. dspcap's Avatar
    My son was playing on mine yesterday and it got to 115, the highest I have seen mine.
    07-28-2010 12:14 PM
  11. knifeahoepro's Avatar
    After playing Pocket Legends or/Gun Bros for 20 minutes my 3500 Seidio gets to be around 118-125F usually my Widgetsoid widget Battery Indicator Health reads Overheating.
    -DInc/Unrooted-Froyo
    04-01-2011 06:49 PM
  12. Jaredshoes's Avatar
    Not sure the exact temperature but ussually if im downloading a game or an app and maybe texting itll get pretty hot
    original battery
    04-01-2011 08:31 PM
