1. glacierfanclub's Avatar
    Hi guys,
    I have a rooted Incredible that stopped working tonight. It can't load past the HTC screen that shows up when you turn it on. I'm going to need to take it back to Verizon. Is it being rooted going to be a problem as far as replacing it?
    08-08-2010 08:07 PM
  2. howarmat's Avatar
    well i doubt they even notice but if you can unroot i would, something tells me you wont be able to if that is all the further you get in the boot sequence
    08-08-2010 08:09 PM
  3. glacierfanclub's Avatar
    I can get to the recovery screen by doing the hard reset.
    08-08-2010 08:09 PM
  4. douger's Avatar
    If you can get to recovery, you should be able to flash a ROM that will work...
    08-08-2010 08:27 PM
  5. easy1jay's Avatar
    If you can get to the recovery screen, try this.
    1. Remove the micro-sd card
    2. Connect micro-sd card alone to PC.
    3. Move the PB31IMG.zip file back onto it (you should have a copy of this if rooted)
    4. Place micro-sd card back into the phone
    5. Boot back into recovery.
    6. Wait for PB31IMG.zip to load.
    7. Profit or take it back to Verizon.
    08-08-2010 08:29 PM
  6. glacierfanclub's Avatar
    wait...think that worked...
    08-08-2010 08:33 PM
  7. glacierfanclub's Avatar
    phone is working now, but had to load an old version and lost everything.
    could be worse!
    08-08-2010 08:34 PM
  8. glacierfanclub's Avatar
    got a backup working. whew.
    08-08-2010 08:56 PM
  9. easy1jay's Avatar
    Hurray!
    08-08-2010 08:56 PM
  10. rpfarrah's Avatar
    Yet another testimonial to the sharp guys here on this forum. Well done!
    08-08-2010 11:12 PM
