Page 1 of 2 12 LastLast
Results 1 to 25 of 29
    Fillyo's Avatar
    Posts
    Global Posts
    598 Global Posts
    Default Battery LIfe
    I have been using this phone for almost a week, and I sorta knew battery life is bad, but not this bad. I can barely get 6 hours on a full charge. I have read up on this and found some tips and tricks, but nothing that has really helped. I just installed task killer. I have one exchange account that I have set to receive messages as they arrive. My comcast checks every half hour. I have a Pandora widget, as well as the HTC calender widget, which syncs with my Outlook exchange account. I turnoff wifi, bluetooth and gps when not using. I don't have too many other things syncing, and I do not use a ton. I am not sure what else I can do. This phone is incredible, except for the battery life. I could atleast get through the day on my Storm 2.
  2. #2
    Default
    My solution was to get three extra batteries and two cradle chargers off ebay for about $25.
    Now I just swap in a fresh battery before leaving work and I am good for the rest of the day. On my day off, I have the other charger at home with a battery there.
    There are larger batteries available, they go for something like $40
    Stephen
    The Incredible Nexus
  3. #3
    BSG75's Avatar
    Custom User Title
    Posts
    Global Posts
    1,055 Global Posts
    ROM
    Jelly Belly
    Default
    Put it in airplane mode for an hour here and there, if you aren't using it and can afford to be without service. There're two stickies at the top of this forum about battery life. Personally, I rooted and put on setcpu. That helps. The big profile setting is that I turn the CPU down to 460mhz when the screen is turned off.
    I also just bought a 2150 extended battery from Verizon (I get an 18% discount) for about $45. I did this because sometimes I have latitude on for a few hours at a time with no access to a charger and I don't want to run any risk of running out of juice.
    First day with new battery: Up for 15hours, awake for 5 hours. About 50% battery used. I also had setcpu turned off by mistake. I just turned it on.
    Please use the Thanks button below and to the right.
  4. #4
    Default
    FWIW, you may not be ultimately happy with Task Killer (Google is your friend). If that happens, and you still want to "manage" your apps, give System Panel a shot.
    ...my $.02.
  5. #5
    cadman's Avatar
    Resident Ringtone Maker
    Posts
    Global Posts
    6,822 Global Posts
    ROM
    BB JB
    Default
    I can get through a full day on the regular battery.
    Turn off the always on mobile option in settings, disable auto screen brightness, search this forum, etc.
    How to install an Invisible Shield
    3rd GN 2-29-12
    2nd GN 1-1-12
    1st GN 12-17-11
  6. #6
    sloan31's Avatar
    Posts
    Global Posts
    577 Global Posts
    Default
    I leave my phone connected to wifi network while at work and at home, I've noticed much battery life improvement when staying connected to wifi instead of 3g.
  7. #7
    davidnc's Avatar
    Posts
    Global Posts
    5,624 Global Posts
    ROM
    Nexus(AOKP-jb_4.2.1)
    Default
    I dont use a task killer ,I let the OS handle my phone. I use moderate to light use depending on how much time I can use the phone and still get other stuff done , lol . I get about 14 hrs to 16 hrs easy , and not totally drain of battery power on a stock battery .I just tweak the settings and searched the tip section to set everything up .I dont have my incredible with me today got the DX . Today was its day off
    SGSIII : White 32 gb model with 32 gb sdcard
    RoM : CleanRom 5.5.1_ jb
    Kernel : n/a
  8. #8
    Default
    I can usually make it just about a full day (~14 hours) with moderate use on a single charge with background data, autosync, and always-on mobile data set to on. I leave Bluetooth off almost always as I find it's a huge battery sink (never has been with my previous phones though), and I leave Wi-Fi off unless I'm at home or the office. I also use auto-brightness, no task killers, and GPS is almost always on. I'm usually in areas that have pretty good Verizon signal saturation, that may have something to do with it.
    Best tip I can give is to get yourself a couple of extra chargers. I keep a microUSB cable at my home and work computers, a car charger (I always plug in for Pandora or Google Nav), in addition to the standard charger which I keep next to my bed.
  9. #9
    Default
    Quote Originally Posted by tony bag o donuts View Post
    Dont do this. It will mess your exchange email up.
  10. #10
    Default
    I have always on mobile network disabled and I have no problems with exchange email (I always get new emails, but you have to manually sync up read/deleted).
    I'm betting Calendar is a problem. It kept my phone from sleeping. And the widget has other downsides (too frakin big, looks amatuerish, no added functionality). I recommend ditching the widget and getting Android Agenda Widget from the market (much more customizable). Then use ATK to keep the Calendar app from loading up. That's kept it under control for me.
    Otherwise, set programs that sync to do so less frequently (comcast, weather, facebook, etc).
    Edit: if you want to see if you have a sleep/wake problem, go to Settings, About Phone, Battery. You're Up Time should be significantly larger than your Awake Time. If they are equal or very close (and you do not use your phone constantly), something is preventing sleep. To find out what, get the app "Spare Parts" from the market. In Spare Parts, go to Battery History and select "Partial Wake Usage" from the top menu. The largest value is probably the culprit (unless it is Android System).
  11. #11
    Didimus's Avatar
    Posts
    Global Posts
    138 Global Posts
    Default
    Try turning off your phone when you charge it. I can get through a whole day no problem with this tactic.
  12. #12
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Default
    3500 battery. I now use my phone with out fear.
  13. #13
    Cyder's Avatar
    Posts
    Global Posts
    173 Global Posts
    Default
    I can go a full day on the stock battery. About 15-16 hours. At the end of the day I am in the yellow to red part of the battery, but by then I'm ready to charge my phone. I am looking into getting the bigger battery though.
  14. #14
    Default
    Quote Originally Posted by PvilleComp View Post
    Today is my first day using the 2150 extended battery. I'm still fearful since theres no case on it but besides that I'm using this thing nonstop.
    I was able to get 3-4 hours awake time with the 1300 battery and 4-5 hours awake time with the 1500 battery. I can't wait to see the awake time with the 2150 battery.
  15. #15
    Default
    From my experience with my DInc. My original battery needed a week of use before the battery seemed to reach it's full potential. I got two extra batteries and the wall charger off of Ebay ( I made sure to get HTC HD2 batteries, they are 1500's and HTC branded ) for $16 and so even if I am away for the weekend I don't need to stress about batteries. As has been mentioned on this post charging your phone does not charge the battery to the same level as the wall charger does, charging the phone the first 10% of battery life goes quickly where when charging from the wall charger actually charges the battery to full. Now that I have all of these batteries and don't need to worry about it I have also found out how to manage my phone to hold the battery life, I have all the widgets and use them. I no longer keep my GPS on until I need it, I have changed my sync times to every 10 minutes and while I am in the office or at home i use Wi-Fi instead of mobile. I never run out of battery before I get home. hope this helps.
  16. #16
    Default
    For those interested, I read on a different forum that the code "bat30" will give you a thirty percent discount off any battery. I bought the extended on Friday. I just called vzw and they are crediting me the difference.
  17. #17
    Default
    I second this! I've had my 3500 for a little over a week now and it has never been under 60% charged when I go to bed. Usually 14-16 hours of usage. I can finally use the phone to its potential without having to worry about the battery dying by 6pm. It is a little bulky but that is a trade off I am willing to make.
    Don't waste your time with the 1750. I made the mistake of wasting my money on that before I bought the 3500.
  18. Thread Author  Thread Author    #18
    Fillyo's Avatar
    Posts
    Global Posts
    598 Global Posts
    Default
    Well, today was really wierd, I charged all nite, accidently (from 12 -6 a.m.), then powered down this morning, powered back up, charged, to like 97%. I get to my office around 9, received a bunch of emails, a little bit of browsing, and a few short phone calls. It is now 7 o'clock and I am still at 55%. Changes made from yesterday: changed one my POP3 account to every 30 minutes from every 15, changed caleder widget to agenda widget, and shut off droid eye live wallpaper. This is the longest I have made it yet. This phone wasn't new, month old, bought in Crackberry forums.
  19. #19
    Default
    Yeah, between the live wallpaper and the calendar widget, I'm not surprised you had problems. Glad things are looking up!
  20. #20
    mudpud's Avatar
    Posts
    Global Posts
    354 Global Posts
    Default
    Quote Originally Posted by rmb View Post
    I wish - my 3500 doesn't last more than 12 hours...so to be on the safe side, I charge it while at work.
    I've done everything - ATK every 30 mins, I don't even do that much browsing. I never charge my phone while off b/c then the alarm won't ring. And I don't like turnign it off. The 3500 sucks ***.
    ~~~ Android Rox ~~~
  21. #21
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Default
    Quote Originally Posted by mudpud View Post
    If you are only getting 12 hrs on a 3500, something is chewing up your battery. What's showing in the Battery usage? Only time I use up the 3500 in a day is under very heavy usage.
    I don't use a task killer.
    Today was a pretty normal day, about 90 e-mails, 15-20 Phone calls most with BT speaker, GPS Nav, GPS Sensorly, Some W-Fi, Lots of surfing on Wi-Fi and 3G. and I'm still at 60%
    Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig.
  22. #22
    davidnc's Avatar
    Posts
    Global Posts
    5,624 Global Posts
    ROM
    Default
    Also in addition to my battery lasting me all though the day just as a precaution I carry the primo cube (a remote power source) and can charge my phone anywhere ,anytime . I did not want the extra bulk an extended battery adds to the phone size.I wanted to keep the incredible slim and trim, not fat lol
    Kernel : n/a
  23. #23
    Qazme's Avatar
    Posts
    Global Posts
    2,956 Global Posts
    ROM
    Bugless Beast 4.1.1
    Default
    Quote Originally Posted by davidnc View Post
    How well does the primo cube charge your phone? I have looked into those to keep it available when I'm going to be away from a charger or left it at home and am using my phone really heavy. But still kind of iffy on ordering one or not.
    The Storm has cleared to an Incredible day! I ate an IceCream Sandwhich. Still needed JellyBeans. ;-)
    NEXUS!!!!!!
  24. #24
    Default
    i always had ok life with stock battery starting the day around 6am and going until around 8 or 9 pm with moderate use but after a bad speaker and getting a replacement phone i am now dead at 1 or 2 pm with the same use. nothing changed on the phone, same apps and settings. i used my backup pro to restore the new device to the same as the old one. does anyone have any sugestions please. the device did act funny durning the restore process so i have thought about a factory reset but hate to loose all my e mail settings, for backup pro did not save them.
  25. #25
    jharo's Avatar
    Posts
    Global Posts
    543 Global Posts
    Default
    Quote Originally Posted by ktrent View Post
    Have you tried "bump charging" your phone a couple of times.
