Results 1 to 2 of 2
    dudleynascar's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default sound when dialing
    Is there any way with a non-rooted phone to disable the sound when using the phone keypad? All other sounds are disabled when pressing the screen.
  2. #2
    davidnc's Avatar
    Posts
    Global Posts
    8,984 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Are you meaning the to silence the numberpad when dialing a number ? If so try :
    MENU button>settings>sounds&display>Audible touch tones>tick quiet box.
    dudleynascar likes this.
