Results 1 to 8 of 8
- 08-31-2010, 03:37 PM
Thread Author #1
Problem playing wav files
Background: Where I work, we have a Cisco VOIP system and it is set up so that when someone leaves a voice mail on my office extension, the Call Manager converts the voice mail to a wav file and emails it to me as an attachment.
Problem: I updated to 2.2 this morning. Since the update, I have not been able to listen to these attachments. Tried saving the wav files to the sd card and playing them through a few different media players, but none of them are working. I tried Verizon support and they were no help, other than they are going to report the problem to Google.
Anyone have any ideas on how I can get this to work again? Thanks in advance. - 09-01-2010, 11:55 AM
Thread Author #2
- 09-01-2010, 01:04 PM #3
This is a known problem that is related to the StageFright audio codecs that Google added to Froyo. Those codecs also reduce the bitrate on streaming music services, which is why Pandora, Slacker, and others sound a lot worse on the current build.
There is an app in the market called Remote Wave that should still work, although I haven't tested it.Thanked by: - 09-01-2010, 01:07 PM #4
- 09-01-2010, 01:24 PM #5
Google has already released a patch, but it does not appear to have made it's way into this build.
http://www.androidcentral.com/fix-co...o-audio-issuesThanked by: - 09-01-2010, 03:25 PM
Thread Author #6
- 09-01-2010, 03:38 PM #7
I should clarify that I don't know if the patch fixes the WAV problem -- it could just fix the AAC audio problem. Time will tell, I guess. You can apply a fix if you are rooted, but otherwise its a waiting game.
- 09-01-2010, 04:49 PM #8
Reply
