Any similar fix for those of us who don't want to root?
Taken Off Of the XDA Forums,
1.) With the phone ON, charge till the reported battery status is full/green LED.
2.) Turn Phone OFF and then charge until LED turns green again.
3.) Boot to recovery mode and go to console (or adb shell) and type:
mount -a
rm /data/system/batterystats.bin
You can also remove this file with the "Root Explorer" app from the market.
4.) Once the file is removed, Power the phone off once more and charge it till the LED is green, then turn it back on. Once at the homescreen, unplug it from the charger and then use it until the battery dies completely. (phone will shut itself off)
6.) Charge it fully again.
After this, you should notice you now have better battery life.
After doing these steps, now when I unplug my incredible from the charger, it sits at 100% battery for a while.. I could send a few text's.. browse a couple web pages and it does not move from 100%
Before I did this trick, the battery life would drop to 89 - 93 % within a few seconds.
Hope this trick works for you all, as it worked great for me! Also if this was posted already, just ignore me..
Could you (or someone) provide details on how to:3.) Boot to recovery mode and go to console (or adb shell) and type:
mount -a
What is S-OFF? Is it something I have to get from the Market?Are you rooted?
If not, you can't do this.
If you have S-OFF, you can use Root Explorer to make this change and then just reboot the phone (power off, power on) unless you have Quick Boot and skip the adb commands.
mount -a
If you have amon ra there's an easier way of doing this step. Just boot into recovery then wipe battery stats
And S-off is having nand unlock. No its not something in the market. You need to be rooted to achieve this then run toasts nand unlock from simpleroot (step 2)
This is the solution I use and it works fine for me. In the larger scheme of things 20 min with the phone off is not a big deal to me and I don't want to go through the extra steps (removing the phone case + removing the back panel from the phone) every time I charged the battery externally. I'll be rooting as soon as unrevoked fix their "Evo bug", so I plan to test the OP's solution soon. Thanks for your update though, it confirmed that I'm doing the "charge bump" right.The solution if you don't want to root...
Charge the battery up until the light is green. Turn your phone off. You'll notice the light will now be orange. Let it charge to green again and when you turn it back on it will stay at 100% for a while.
But I do not like that method because during the 20 minutes or whatever it takes to charge back to green while the phone is off I might get an important call or text message. Especially the call I wouldn't receive.
You can also do it in clockwork recovery.
