Results 1 to 13 of 13
- 09-04-2010, 04:04 PM
Thread Author #1
Strange problem while trying to update. NEED HELP!
I saved the update file to the root of my SD card. I also changed the name to update.zip not update.zip.zip. I loaded to the bootloader and a quick few lines flash saying incorrect .zip file or something along those lines. I then hit recovery and it takes me to another menu which allows me to reload bootloader wipe my storage reboot etc. I've been trying to update unsuccessfuly for days now and need help. Also I received the OTA update and chose update now. Nothing happened no matter how many times I clicked update now then the message disappeared. I dk what's left to do my luck is awful with this phone :-/
- 09-04-2010, 04:32 PM #2
What have you done with your phone, patches, roms, kernels, change to the internal files etc...
Tablet: Nexus 7 16gb Stock Rooted - Jelly Bean 4.1.1 - TWRP Recovery
Active Phone: VZW - HTC ReZound - Rooted/JuopunutBear S-Off - Stock GB 2.01.605.11 ROM
HotSpot: VZW - Samsung SCH-LC11 4G Mobile Hotspot
NEW! ReZound Splash Screen Web Generator Link - 09-04-2010, 04:52 PM
Thread Author #3
- 09-04-2010, 04:59 PM #4
- 09-04-2010, 05:06 PM
Thread Author #5
- 09-04-2010, 05:09 PM
Thread Author #6
- 09-04-2010, 05:22 PM #7
This may sound silly, but are you using windows 7? Use a file manager to make sure the update.zip is visible on your sd card before booting in recovery. I ran into this issue and had to install some driver of some sort to move the file from my laptop to my phone successfully. It took a few tries before it showed up on the sd card, and once it did, I was in business.
"In valor, there is hope." - 09-04-2010, 05:33 PM
Thread Author #8
- 09-04-2010, 05:40 PM
Thread Author #9
- 09-05-2010, 03:43 PM
Thread Author #10
- 09-05-2010, 04:52 PM #11
Update the HTC sync driver. I had the same problem. I unistalled HTC sync from my computer and plugged the phone back in. It updated the driver automatically. When your computer tells you your device is ready to use, move the file over to your sd card. Unplug your phone and use a file manager to make sure it is there. Then boot in recovery and grab a spoon...
"In valor, there is hope." - 09-05-2010, 08:55 PM #12
Gawd, I'm glad I'm rooted...
- 09-07-2010, 11:33 AM #13
Reply
