How to listen to Sirius Satellite Radio?
dotcomer
With this new update ,I figured I would be able to listen to my favorite Howard Stern on Satellite Radio and its a no go. Can anyone give me any advice on how I can do this?
VZWBB
261
As far as I know, the internet sirius player does not allow you to listen to stern and neither does the android app. So I think your out of luck.
Revolutionary
876
21
The internet stream works for Stern (100 and 101), but not for mobile devices. I believe there is a way to do it through Orb (orb picks up the stream off your home PC and streams it to your mobile) -- but I'm not familiar enough to tell you how. Should be threads here. Search 'sirius' across all the forums (not just the Incredible forum).
lucharmer
