Results 1 to 9 of 9
    fbords's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default What's the difference?
    I'm currently waiting for the unrevoked 3.2 tool to be re-released, and was wondering, for someone like me that just wants a simple root, what's the difference between unrevoked 3 and unrevoked forever? What will one get me over the other?
  2. #2
    PvilleComp's Avatar
    Posts
    Global Posts
    4,265 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM-7
    Default
    Unrevoked3 is the root tool and recovery flasher. Forever turns the security signing on or off. It looks like the 3.2 release also does Forever. I had an s-off/on option in the recovery when I did mine last night.
    Hope this helps.
    fbords's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    So would i just need to run the new unrevoked 3 tool when it comes out and be good, or will i need to run the forever tool afterwards? Does this make it so I can just turn s-on when waiting for an OTA, then turn s-off after?
  4. #4
    PvilleComp's Avatar
    Posts
    Global Posts
    4,265 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM-7
    Default
    You would need to flash back the stock recovery for OTA's.
    I was looking at the recovery but I can't seem to find where I found the s-off/on last night so you may need to run Forever as well.
    fbords's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    ok so if i just want root, I can just run the first utility, then if I want s-off, I can run forever? will just doing the 3.2 update by itself cause me to lose any important functionality?
  6. #6
    PvilleComp's Avatar
    Posts
    Global Posts
    4,265 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM-7
    Default
    3.2 should not change anything on the phone excpet for giving you root.
    fbords's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Thats what I was looking for. Is forever required to flash custom roms, or just "unofficial" ones that are unsigned?
  8. #8
    Revolutionary's Avatar
    Posts
    Global Posts
    1,157 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by fbords View Post
    No. Forever just means that even if the current exploits to attain root are patched in future software updates, your phone will still be able to load a custom recovery utility, so you can still flash roms (which can give you back root access).
    public:forever [RootWiki]
    fbords's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Revolutionary View Post
    ahh, so it shounds like I should do both...
