Results 1 to 9 of 9
    Default USB connection with mac
    just a question - every time i connect my DInc with my Mac, an error message pops up - "The disk you inserted was not readable by this computer". any idea how to fix that?
  2. #2
    Default
    I ran into the same issue, and believe it's the HTC Connection Manager trying to install on the computer. I've noticed this ever since upgrading to 2.2. If you plug it into a Windows PC, a pop-up will ask if you want to install it.
    Unfortunately, I also have no clue how to fix it.
    EDIT: Don't worry though. You can hit ignore, mount the disk, and it should function properly...
  3. #3
  4. #4
    teddeli's Avatar
    Posts
    Global Posts
    178 Global Posts
    Default
    Quote Originally Posted by galactor View Post
    I just tried it. I can confirm that this works. But what will happen or not happen when connecting to my PC. Will I be missing something?
  5. #5
    Default
    Quote Originally Posted by teddeli View Post
    This works the same for both Mac and Windows. On the Mac it is more annoying because it shows up as a "drive error". On Windows you will only get a 3rd drive (Verizon). As far as I know you don't need it even if you use Verizon's syncing software (for Windows). Once you follow the instructions above, the drive wont' show up on either Mac or Windows.
  6. #6
    Default
    worked for me! thanks
  7. #7
    Default
    Great! Thanks for the info.
  8. #8
    Default
    This is awesome. I actually just made a thread...my bad. This works perfect.
  9. #9
    Default
    Quote Originally Posted by bandanaMan View Post
    I've been here for less than a month and I see duplicate threads all the time. Search function is not great, it just requires some patience. Still, lot of people willing to help
