1. Jowlah's Avatar
    I have been looking for a good battery indicator app that will show my battery life in either a number or a percentage in the notification bar. But one that doesn't rape my battery. Anyone have suggestions or recommendations?
    09-29-2010 01:29 PM
  2. BSG75's Avatar
    I have not used them, but you can check these out:
    battery widget - Search Android Apps on AppBrain
    09-29-2010 02:35 PM
  3. IncredibleMike's Avatar
    Great question. I too would like to know the answer.
    I am currently using "Fann Software Battery Status" but this might be drawing some more power than I was hoping - even for a widget.
    09-29-2010 02:39 PM
  4. MrBigFeathers's Avatar
    Battery Indicator Pro
    09-29-2010 03:29 PM
  5. kicko's Avatar
    +1 try the free version
    09-29-2010 03:37 PM
  6. KB3MMX's Avatar
    Gauge battery widget, by Thomas Hulabek !!
    Great looking and lots of options.
    09-30-2010 11:10 AM
  7. BBKik's Avatar
    I have come to believe that as a whole Dinc owners(I am including myself) use as much battery checking the battery and draining it. We are so worried about our batteries that we will pick up our phones and check for no reason, thus using more battery resources.
    09-30-2010 11:45 AM
  8. dragonsamus's Avatar
    I agree. I felt ocd with it. I've since installed it. I was using battery indicator pro.
    09-30-2010 04:24 PM
  9. galactor's Avatar
    OP, if your phone is not rooted, the first widget from the list posted by BSG75 is pretty good.
    09-30-2010 05:07 PM
  10. teddeli's Avatar
    I did exactly that. Tried the free and upgraded to the pro. Well worth the 99cents. This app does not drain the battery.
    10-01-2010 08:00 AM
  11. Jowlah's Avatar
    Here's the thing. I used Batttery Indicator and I lost 5% of my battery life in 20 mins. That's the contradiction. Although it does have a lot of functionality, it defeats the purpose of the app. Any other app you guys can think of?
    10-01-2010 06:30 PM
  12. wckesq's Avatar
    Been running Battery Left App for the last week and am pretty happy with it. Give it a try. it's free.
    10-01-2010 06:52 PM
  13. weihl165's Avatar
    +1 on gauge battery widget
    10-03-2010 09:43 PM
  14. Jowlah's Avatar
    I know that this is an old thread, but Battery Status by Modded Logic is one of the best battery apps you can get. Very customizable and doesn't kill your battery.
    09-30-2011 06:46 PM
  15. OverLordOfYou's Avatar
    CIRCULAR BATTERY INDICATOR its the best if you want a top bar numeric display of what percentage your at. Also very little if any drain that I've seen in 5+ plus months I've used it. It gives you a nice little color change circle that goes with the level your battery is at around the percentage. Plus you can access your "view battery use" when you click on it.
    Sent from my ADR6300 using Tapatalk
    10-08-2011 08:12 PM
  16. jmk32's Avatar
    [QUOTE=OverLordOfYou;1326843]CIRCULAR BATTERY INDICATOR its the best if you want a top bar numeric display of what percentage your at. Also very little if any drain that I've seen in 5+ plus months I've used it. It gives you a nice little color change circle that goes with the level your battery is at around the percentage. Plus you can access your "view battery use" when you click on it.
    Sent from my ADR6300 using Tapatalk[/ QUOTE]
    + 1 for circular battery. Been using for over a year and no drain
    10-09-2011 10:01 AM
