Is there any way to keep sense on my droid, incase i dont wanna keep using launcher pro. im willing to try launcher pro but if i dont like it i would like to be able to go back to sense! is it possible?
If you install launcher pro it will just run on top of sense. It wont uninstall sense so it will still be there if you want to go back to it. Theirs an app in the market that will let you switch between the two if you wanted to i think its called home switcher and i believe it is free.
I looked for it but it says its not supported with Froyo 2.2, which i have running on my Dinc, idk if it'll be possible to use without rooting atleast
