1. AC Question's Avatar
    I thought the red cross lines were an indication that my phone had got wet, but learning maybe not. However, took it to One day Phone repair and they said they could dry it out, but later found out it's doing the same for them as for me, powering on and off without fully uploading. The battery had got extremely hot and I had to remove it to cool it off. He said he dried it in a dryer box but I believe I might have been taken. Wouldn't he have known what the cross stitch meant? Could my battery be the cause of my phone misbehaving? I just don't want to loose my voicemail, photos and text messages.
    Tiansiti likes this.
    06-30-2014 09:54 PM
  2. Golfdriver97's Avatar
    Water damage may be causing some of this. If a phone gets wet, placing in a bag of rice, or with several bags of silica should remove moisture.
  3. Tiansiti's Avatar
    Need help with this too...
    06-30-2014 10:36 PM
  4. Golfdriver97's Avatar
    09-19-2014 10:15 PM
  1. Question for you that were/are on the Edge Plan with VZW
    By brucedbr in forum Samsung Galaxy Note 4
    Last Post: 09-24-2014, 05:37 PM
  2. Why is the max charge on my Note 2 capping out at 72%?
    By AC Question in forum Samsung Galaxy Note 2
    Last Post: 09-24-2014, 12:35 AM
  3. htc inspire
    Last Post: 09-24-2014, 12:24 AM
  4. Replies: 0
    Last Post: 09-23-2014, 06:10 PM
  5. Replies: 0
    Last Post: 09-23-2014, 04:25 PM
