1. kmully's Avatar
    I realize how dumb of a question that is. I know there are several battery threads out there, but those seem to be discussing leaving the phone on overnight.
    Here's my issue: I turned off my phone (with wifi still active) last night with about 32-34% battery according to the battery widget. As in... I turned the phone off. Completely off.
    I woke up this morning to find myself with 13% battery and the warning that I needed to plug my charger in.
    ...scratching my head as to how that's even possible.
    Thoughts? Could I have some sort of module on the phone that is staying on overnight and slowly draining it?
    11-23-2010 12:52 AM
  2. gtricecakes's Avatar
    It takes a bunch of charge to turn your phone on and off, especially on. That is probably why the battery decreased that much.
    11-23-2010 06:45 AM
  3. KayIslandDrunk's Avatar
    Wow, that's pretty odd. You might have a short somewhere. I usually leave my phone ON overnight and it only uses about 15-20% of the battery.
    11-23-2010 04:25 PM
  4. BSG75's Avatar
    Just to be clear, it sounds like you let your phone go to sleep, you are not turning it off. Even when asleep, it does some polling every now and again to look for app updates, email, text messages, etc. Also, if the cell radio on that will use up juice periodically.
    If you don't need to get updates while you sleep, I suggest putting it in airplane mode before you go to bed. With all the radios off it uses almost no power.
    11-23-2010 05:08 PM
  5. kmully's Avatar
    No... I am holding down the power button, selecting "power off", confirming I want the phone powered off, and it turns completely off. Off to the point where I have to wait on the device to start back up (HTC Incredible screen, annoying "Droid" sound plays, etc.)
    I still can't believe turning on the phone zaps 20% of the power in one fell swoop. Baffled.
    11-23-2010 10:58 PM
  6. kcinkiller1's Avatar
    yes, that much power loss does seem excessive especially if you turning it off all of the way....maybe later i will try n run a test to see how my battery reacts wen turned off with wifi on then turned on later...hmm
    11-24-2010 03:47 AM
  7. BSG75's Avatar
    Yeah, that is weird. Sorry. I got nuthin.
    11-24-2010 07:27 AM
  8. davidnc's Avatar
    Have you tried that *#*#4636#*#* thing to see you battery history and stats to see if that offers any clues yet?
    Sent Using TaPaTaLk
    11-24-2010 08:52 AM
