1. Kratzer's Avatar
    In my software info I have
    ANDROID VERSION
    2.2
    BASEBAND VERSION
    2.15.00.07.28
    KERNAL
    2.6.32.17-G9A2FC16
    HTC-KERNAL@U18000-BUILD149 #1
    BUILD NUMBER
    3.26.605.1 CL264707 REALSE-KEYS
    SOFTWARE NUMBER
    3.26.605.1
    BROWSER :
    WEBKIT3.1
    PRI VERISON
    1.28_002
    PRL
    52167
    ERI VERISON
    5
    THEN HBOOT SAYS
    INCREDIBLEC XC SHIP S-ON
    HBOOT- 0.92.0000
    MICROP- 0417
    TOUCH PAN...... ETC
    RADIO - 2.15.00.07.28
    I appriciate it very much, thank you!
    12-06-2010 09:32 PM
  2. droidfrk's Avatar
    You can go download superuser permissions to test if you are rooted and also you can download titanium backup and see if it will let you back anything up to test. Im not positive but i dont think any of this info tells you if your rooted or not. Hope this helps
    12-07-2010 08:02 AM
