1. crwmlw#IM's Avatar
    Im getting a screen on the home screen thats says System UID's Inconsistent
    UID's on the system are inconsistent, you need to wipe your data partition or your device will be unstable. Then there is a box that says Im feeling lucky that you can click on.
    Any ideas please?
    Mayank Thakur1 likes this.
    12-08-2010 04:37 PM
  2. mclarryjr's Avatar
    Have you downloaded any app's lately? Sound like you got a bad app.
    12-08-2010 04:41 PM
  3. crwmlw#IM's Avatar
    LOL. Always downloading apps. Any ideas on which one it could be? Does it sound like an app?
    12-08-2010 04:52 PM
  4. CRKhead's Avatar
    Doing a Google search points to a lot of ROM's installed on the phone, although not all of them, and the end result is usually a factory reset.
    Are you rooted / unrooted? Installed any ROM's?
    12-08-2010 05:01 PM
  5. crwmlw#IM's Avatar
    No. None of those
    12-08-2010 05:05 PM
  6. CRKhead's Avatar
    I'm Googling the error, and the end result keeps on showing up as a Factory Reset... I'm not looking through every little detail though... Do some more research, maybe you can find an alternative to resetting...
    12-08-2010 05:09 PM
  7. crwmlw#IM's Avatar
    Ok. Thanks. I dont know what the hell happened. Im not even rooted.
    12-08-2010 05:11 PM
  8. CRKhead's Avatar
    A lot of the posts also make reference to a file on the SD card... Have you tried removing the SD card and rebooting?
    12-08-2010 05:16 PM
  9. crwmlw#IM's Avatar
    Yes I did that as well. I had to reformat and lost everything of course. I just want to make sure there is nothing I did to have this happen again.
    12-09-2010 06:05 AM
