Results 1 to 9 of 9
    Default HELP PLEASE> System UID's Inconsistent
    Im getting a screen on the home screen thats says System UID's Inconsistent
    UID's on the system are inconsistent, you need to wipe your data partition or your device will be unstable. Then there is a box that says Im feeling lucky that you can click on.
    Any ideas please?
  2. #2
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,356 Global Posts
    ROM
    NOS M7 Sense 5.0
    Default
    Have you downloaded any app's lately? Sound like you got a bad app.
    Default Always
    LOL. Always downloading apps. Any ideas on which one it could be? Does it sound like an app?
  4. #4
    CRKhead's Avatar
    Posts
    ROM
    Standard 4.1 Jellybean
    Default
    Doing a Google search points to a lot of ROMs installed on the phone, although not all of them, and the end result is usually a factory reset.
    Are you rooted / unrooted? Installed any ROMs?
    Galaxy Nexus, Droid Incredible
    Circle Me on Google+
    Twitter: @CRKhead
    PSN: CRKhead
    Default Unrooted no roms no
    No. None of those
  6. #6
    CRKhead's Avatar
    Posts
    ROM
    Default
    I'm Googling the error, and the end result keeps on showing up as a Factory Reset... I'm not looking through every little detail though... Do some more research, maybe you can find an alternative to resetting...
    Twitter: @CRKhead
    PSN: CRKhead
    Default Ok
    Ok. Thanks. I dont know what the hell happened. Im not even rooted.
  8. #8
    CRKhead's Avatar
    Posts
    ROM
    Default
    A lot of the posts also make reference to a file on the SD card... Have you tried removing the SD card and rebooting?
    Twitter: @CRKhead
    PSN: CRKhead
    Default Yes
    Yes I did that as well. I had to reformat and lost everything of course. I just want to make sure there is nothing I did to have this happen again.
B
