1. linwiz's Avatar
    I can't get my SD card or phone storage to mount to my computer (PC, running ubuntu). I have never had an easy time doing this but now i think its just not going to mount any more. i did recently run unrevoked3.22 and flashed Virtuous v3.1.0 as well. I have frozen some things using titanium backup, eg i froze HTC Sense as i use Android Mate... but freezing that shouldnt give me this issue? im thinking its virtuous that is the problem.. any takers?
    12-08-2010 08:10 PM
  2. PvilleComp's Avatar
    I have Virtuious and it's mounted to Win XP and 7 with no problems. Haven't tried it with any Linux distros though. Try unfreezing Sense, HTC may have some mounting code in there buried in the mire.
    Hope this helps.
    12-08-2010 08:45 PM
  3. linwiz's Avatar
    i tried that, im trying to wipe and reflash now
    12-08-2010 09:08 PM
  4. linwiz's Avatar
    i am now completely back to stock, unrooted, stock rom, S-ON no titanium backup at all..and still cant mount.
    edit: okay and now its mounting again, i decided to try and mount it to my wifes macbook and it worked.. then i went back to my linux laptop and it worked.. hmm.
    12-08-2010 11:54 PM
  5. s_franchise's Avatar
    maybe when you went back to stock it recognized the drivers?
    12-09-2010 02:50 AM
  6. linwiz's Avatar
    no drivers needed on linux.. and even after i went stock it wouldn't mount
    12-10-2010 08:19 PM
