Results 1 to 3 of 3
- 12-16-2010, 05:08 PM
Thread Author #1
Signal Meter after Maintenance Update
My signal strength meter seems to be off every since the last 2.2 maintenance update. I keep seeing the meter fluctuate a lot, even when the phone is held in the same spot. I did a factory reset and *228, but this hasn't made any difference. Have any of you had a similar issue? If yes, any advice?
- 12-16-2010, 07:44 PM #2
i've seen mine jump to full bars and back down a few times, but it hasn't bothered me.
- 12-18-2010, 08:13 PM #3
Yes and 3G data seems much more unstable after the November update.
Nothing we can do about it unless you hack/root your phone.
Reply
