Results 1 to 9 of 9
    Smile Handcent Notification- number of Messages
    I am using handcent to get my messages. I am on the run and wish I could look at home screen and see how many text messages I have waiting for me if any. Is there a way to have Handcent icon show me how many unopened messages I have? I would prefer not to use the notification bar as it seems to get filled up fairly quicklet. Thanks Forum buds.
  2. #2
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Carrier
    Stock for now
    Default
    Quote Originally Posted by jaybro0813 View Post
    Ive never tried NoLed on any other phone but i imagine it would work. NoLed has a little envolope that bounces around the screen and has a number next to it letting you know how many unread messages you have, you could try that.
  3. #3
    jayhawkfan18's Avatar
    A Dude
    Posts
    Global Posts
    907 Global Posts
    Carrier
    JellyWiz / CM10
    Default
    If you add the icon as a widget it should show you the # of unread messages you have. It does for me
  4. #4
    oletheos's Avatar
    Posts
    Global Posts
    41 Global Posts
    Default
    use the handcent widget instead of putting the app on your home screen. it actually puts a green dot on the app with a number showing you how many
    goalstopper12 likes this.
  5. #5
    BSG75's Avatar
    Custom User Title
    Posts
    Global Posts
    1,059 Global Posts
    Carrier
    AOKP
    Default
    Yup. The small widget. I use it.
    Default
    thank you all I will try that- Forum comes to the rescue
  7. #7
    Cyber Warrior's Avatar
    Robots Will Kill
    Posts
    Global Posts
    11,968 Global Posts
    Default
    I get them every now and then along with my Gmail and phone icons being notified. So it does work....just when it wants to. I wish all the icons would show the message/number count. Seems to be the only bug I experience on this phone. I'm stuck with using the notification bar until I find a fix for it.
  8. Thread Author  Thread Author    #8
    Default
    It worked you guys are the bomb!!
  9. #9
    Default
    I thought handcent did it by default. When I had it it would show messages on lock screen. One thing I miss about it.
    Sent from my Droid Incredible using Tapatalk.
