318sugarhill
For all you siedio fans, I get a full day of moderate use with the stock battery. If you are getting the same, you got ripped off. It's been well documented that Siedio batteries are rated higher than what they actually hold. Just google it. Many 1700 siedio actually hold 1400 or less.
Your best bet is to get a second battery with an external charger like the poster above said. When one dies, swap it out. You never have to plug in the phone again.
