Results 1 to 2 of 2
    Aluminum's Avatar
    Posts
    Global Posts
    23 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Geolocation problem: Location does not exist
    I'm getting this error constantly and I tried to turn all settings off and on and phone on and off, but to no change. THis pops up when I try to refresh the weather with the beautiful widgets app
  2. #2
    Jude526's Avatar
    Posts
    Global Posts
    5,954 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I didn't like beautiful widgets it wouldn't work right on my device. My location wouldn't show up. I have the fancy widget pro and love this application. I have mine set as follows and you may want to try this with your beautiful widget: you also need to make sure you are using the beautiful widget settings and the HTC weather is turned off . (I have a friend who forgot that) I don't remember the weather provider you can use on beautiful widget but with fancy I use google I have checked Use My Location but I don't have the GPS location checked.........if I have that checked it won't give me current city. I find it works best for me to have it by the current location and it works just fine. I know you have a different weather application but hope this helps you a little
