1. stotts.brandon's Avatar
    My Incredible was working as normal until last night. My phone stopped letting me enter apps. Everytime I would try to access one it would "force close". I shut my phone off. When I turned it back on it went to the 'htc Incredible' screen as normal, and then to the 'htc quietly brilliant'. Then it says, "DROID" does that creepy red eye thing and then goes back to the 'htc quietly brilliant' screen. Where it repeats, "DROID" the creepy red eye thing and then back to the 'htc quietly brillant' screen. It won't stop this cycle. Any ideas of what to do?
    I tried doing a recovery but that only took me to a black screen with a phone in the center. There is a triangle and a ! exclamation point on the right top part of the phone.
    Thanks.
    05-14-2011 09:34 AM
  2. anicholas7's Avatar
    Is your phone rooted?
    05-14-2011 11:05 AM
  3. plemelin's Avatar
    May have to Nuke and pave it.
    05-14-2011 12:06 PM
  4. Jude526's Avatar
    Sounds like you need tech support to check it out. May need a replacement
    sent from my Incredible using tapatalk
    05-14-2011 08:57 PM
  5. redfirecarbon's Avatar
    im haveing the same problem ....... ugh !?! and my droid is not rooted :/
    12-17-2011 08:26 PM
  6. PvilleComp's Avatar
    Try clearing the cache partition - Follow the steps in this post to get to recovery on an unrooted DInc and clear the cache. Don't do a reset or clear data, just cache for now.
    Second GB Update/Patch Won't Reboot Issue - SOLVED!
    12-18-2011 09:32 PM
  7. tuner2399's Avatar
    Yeah mine does that too, let me know if you can figure out how to fix it, I turned mine off in the morning and it wouldn't start, I guess it is what htc phones are like these days
    05-22-2013 04:48 PM
