Results 1 to 5 of 5
    Default Transfer of Info - Droid to Incredible
    Guys,
    Being a relatively new immmigrant from Blackberry to Droid, would we be able to transfer my Droid Contacts, Calendar, Pictures to the Droid Incredible?
  2. #2
    Default
    Contacts and calender should be if you have them backed up in g-mail. pics will also if you back them up on your sd card or on a pc and transfer them. The incredible is not coming with a SD card as far as I know so you can just use the one from your droid.
  3. #3
    Default
    yepp, also im sure if you buy the phone directly from verizon just tell them you want to switch phones and they can move the stuff over for you
  4. #4
    Zombiepug's Avatar
    Zombie
    Posts
    Global Posts
    1,740 Global Posts
    ROM
    Stock
    Default
    Quote Originally Posted by Allendroid View Post
    +1 def. turn on the sync and sync up with gmail so when you turn on your incredible it will pull your contacts and just pop your droids micro sd in and you will be all set.
  5. #5
    Default
    You also have to go to the market and reinstall your apps.
