recently upgraded to cm7 but find the call volume to be extremely low. is there a way to increase this or is this something builders are working on
If you have Voodoo Control on your phone, go to Hi-fi record. Some users have reported this helped fix that problem. My fascinate did not have that issue. Volume is great.There is a known issue where the people on the other end cannot hear the caller well. It sounds very low. Everyone hopes there is a fix for this soon but we won't know until the next build comes out and again, no one knows when that is.
I finally found something that fixed this issue on my phone. I stayed with jt's 7/17 build but flashed the 7/25 CM7Fascinate-OPBJ Kernel that imnuts07 posted on his twitter.
People say they can actually hear me on the other end of the phone now. Hooray!
That didn't work for me. my phone is buggy for some reason.
Are you sure your still on 7/17? It took me a while to figure out that it was 7/17 and the new kernel that worked for me instead of newer CM builds.
Re-flash maybe?
Re-flash maybe?
