[GUIDE] To go from anything to JT's Vanilla GB
BrownSuperman
Active member
Jul 24, 2010
34
5
Back up everything, I'm not responsible for anything you do to your phone. These steps have helped everyone who has come to IRC. Just made a one stop guide.
You shouldn't need to post anything in this thread other than to mention if there is a broken link. If you want to thank me, thank the developers instead. They did all the real work. If you really feel like thanking me after that, you can thank me on IRC instead of making a post. I don't like runaway threads and clutter.
You will need these following files:
On computer:
Odin: https://goo.gl/JT9uU
Stock ED05: http://lp.downloadsetup.net/?sysid=406&appid=484&dynid=120931&subid=20uebd0tcNqV6xTc32MWAG1zAvs2000.
Atlas_v2.2 PIT: https://goo.gl/Hktky
CWM4: http://dl-1.va.us.xda-developers.co....tar?key=UNStPOXyWsr69Itb3MMj-w&ts=1442005364
EC09 Modem: http://dl-1.va.us.xda-developers.co...5.7z?key=jx-mcC41h5l9sa_PkWxqrA&ts=1442005364
GB Bootloaders: https://dl.dropboxusercontent.com/u/14764513/GBBootloaders.zip
Nexus S Drivers: http://developer.android.com/sdk/index.html (SDK download)
http://developer.android.com/sdk/win-usb.html (Explanation)
On SD card on your phone where you can find it:
Vgb version 7: http://kan.gd/xso
Latest Gapps: http://lp.downloadsetup.net/?sysid=406&appid=484&dynid=120931&subid=20uebd0tcNqV6xTc32MWAG1zAvs6000.
STEP 1
A)BACKUP EVERYTHING, make a nandroid, back up stuff in Titanium Backup.
B)Install the Nexus S drivers. You will have to download the Android SDK in order to do so.
STEP 2
A)Start Odin.
B)Make sure Repartition is checked on the left.
C)Make sure atlas_v2.2.pit is in the PIT section
D)Make sure CI500_VZW_ED05_FROYO_REL.tar.md5 is in the PDA section with it checked off
STEP 3
Double check Step 2 and connect your phone into download mode and press start. (Download mode = take out battery, connect phone to computer using USB, hold down volume button and a yellow triangle symbol will pop up)
STEP 4
After it passes in Odin, boot up to stock.
STEP 5
A)Turn off phone and go back into download mode.
B)In Odin press reset and DESELECT repartition on the left.
C)Make sure cwm4_fixed_for_cm7-ODIN is in the PDA section
D)Press Start
STEP 6
Three finger (Volume up + Volume down + Power button) into recovery. If you let it boot up normally it will overwrite CWM and you will have to repeat STEP 5.
STEP 7
A)Wipe data, cache, dalvik
B)Install from SD, navigate to where you put full fascinatemtd ota eng.jt1134 0811 signed.zip (VGB version 6) and install.
STEP 8
A)Let it reboot and boot up all the way.
B)Power off and go into download mode and connect to computer.
C)In Odin press reset and make sure repartition is DESELECTED on the left.
D)Make sure ec09-modem.tar.md5 is in the PDA section
a)You will have had to extract the EC09 modem using 7-zip
E)Press start
STEP 9
A)Let it boot up all the way.
C)In Odin press reset.
D)Make sure GBBootloaders.tar is in the PDA section
a)You will have to extract GBBootloaders.tar as well using 7-zip.
E)Press start
STEP 10
B)Then hold onto power button, press reboot, press recovery. YOU SHOULD NEVER USE THREE FINGER RECOVER ANYMORE. DON'T ASK ****ING WHY OR WHAT HAPPENS IF YOU DO, JUST DON'T ****ING DO IT. ****.
C)Navigate to where you put gapps_update-2.3.5-gb-20110725-signed.zip on your sd card
E)Install then reboot system fully
STEP 11
You should now have Android Market
A)Download ROM manager from Market
a)If your connection/data symbol is white at the top, skip the Google Account process
b)Toggle WiFi or airplane mode once you're fully in the ROM
c)Icon should turn green at the top, open market and log into your Google Account
B)Go to download ROM, jt1134, download the latest VGB version.
a)If a popup says you need a recovery, press yes.
b)Select Fascinate MTD (IF YOU WANT TO FLASH MIUI OR ANOTHER MTD ROM THEN THIS IS WHERE YOU'D FLASH THAT INSTEAD)
c)It'll say something about if you have manually installed a recovery.
d)Press yes then select CWM 3.x.x
C)Wipe dalvik should be selected. Let it do it's thing.
STEP 12
A)Go back into ROM manager and if JT has released a later kernel select that.
B)Wipe dalvik cache should be selected. Let it do it's thing.
STEP 13
Make me a sammich
STEP 14
Restore Apps+Data only from Titanium Backup. Deselect any Google Apps because you now have the latest 2.3.5 versions. DON'T RESTORE ANY ****ING SYSTEM SETTINGS.
STEP 15
Reboot
STEP 16
Profit
If you want to put on CM7 or MIUI, then substitute that ROM for vgb. MIUI doesn't need GAPPS.
If you want to flash a custom kernel such as Glitch and use Adrenaline Shot, reboot into recovery using the reboot menu. Wipe dalvik, flash kernel first, make sure it's for MTD ROMs and not EH09. Let it boot up all the way before rebooting back into recovery using the reboot menu. Then flash Adrenaline shot.
Glitch's kernel : http://forum.xda-developers.com/show....php?t=1252871
dsexton702's Adrenaline Shot: http://forum.xda-developers.com/showthread.php?t=1236779
MAKE SURE YOU USE A UNIVERSAL ANDROID VERSION OF THE TWEAK
Thanks to Jt1134 for sharing his personal ROM and his continued efforts. Also the other devs, Team Hacksung, TeamSbrissenMod, people on IRC, and other people who have contributed and made our phone so damn sexy.
If you wasn't to flash cm7 nightly, you can flash it through rom manager instead of the latest vgb.
Sent from my SCH-I500 using Tapatalk
If I currently have voodoo enabled, do i need to disable it first before beginning this guide?
And just to confirm, you will end up with EC09 modem after its all said and done?
Thanks for your help!
This should wipe out Voodoo since you are using Odin instead of CWM recovery at first. I'd disable it anyways. And yes you will end up with EC09 modem at the end.
Reactions: Canuckfan
After I get everything installed (step 11) I went to *228 to activate the phone and it says its activated but then I get a message saying that it didn't activate and then suddenly I have no signal. This has happened twice now. I had bars prior to attempting the call though. Help?
Also, after I did the JT update in ROM manager my Android market and some other stuff went away.
After doing *228 soft reboot your phone. Your phone did activate and your PRL codes did update, just the message is wrong.
Flash the updated GAPPS. When you updated in ROM manager you weren't supposed to wipe data.
Great rom but, the phone won't stay off when I am charging it. Any ideas? What are my choices in kernals?
Nice write up, thanks. Does this rom have the kill SD card problem possibility since it is EC09 based?
Where can I get CI500_VZW_ED05_FROYO_REL.tar.md5. Is it not available any more or is there something newer?
Stuck on dang boot-loop at step 8a, full boot-up after full
install... Tried it several times from scratch, following all
steps to the letter
The computer also spastically tries to load a new driver during the boot-loop
madness. With the phone back to stock I no longer show an ADB device in the
Device Manager either..?
I was running SC 2.9 before I decided to try something new. :confused:
Searching here and XDA for answers...
Don't exactly know the whys and wherefores but I got it to work using the 'battery in' Odin method.
Thanks dished to BrwnSuperman and one sang'ich served!
bill
Do you have another link for the GBBootloaders? The link is broken.
It just so happens to be attached to a thread just like this one over at XDA.
XDA
Scroll to bottom of first post, also by BrwnSuperman. Assuming I won't be tarred & feathered for posting a link from another forum.
bill
So this sammich... About how long should it take to make because I installed the new kernel about 20 minutes ago and the phone has been stuck on the android boot screen since then...
asnes
